Tanking price
Depends, shower area over bath £60-75ish, walk in shower 2-3 sides £80-£100ish
Normally Aquadefence & I always try to buy it when it's on special & have a few tubs spare in the garage.
I need to double my price then 😉 Do you tell customers what the option is for tanking and cost it as a recommended option?
Same as Andy Allen. I charge £100 I offer it and advise it, but it's there choice. I use tilemaster tanking kit which is nearly £50
I think its priced about right at what I charge, enough for me to make a bit more and cheap enough to protect the ceilings downstairs, unless the plumber forgets to connect the waste 🙄
£20 per m2 usually gives a decent bit of profit, usually works out anywhere between £100-150 for a shower.
I just priced a job today & told them that the shower needs waterproofing.
I'm doing a new build starting tomorrow & ive recommended that the upstairs ensuite shower gets a tanking kit but not sure whether the builder wants to pay the extra or not.
I don't price it separately. It's listed in the quote. Discussed beforehand that it'll be included and explained why. If they don't want it, they don't get me.
I normally use kerdi or ardex wpc if i don't get to build the walls. I will build in a days labour to prep an area (ok, it might just be 2 to 3 hours though!) and materials + 40% so anywhere from 200 pounds upwards built onto the price.
Tanked a new build shower today, amazed that the builder listened to me.
I reckon it took me 4hrs by the time I cut the tapes & put 2 coats of paste on the walls (3 sided shower 900x760)
£80 for the 4hrs work & £50 for the paste roughly so not far away at £150- £200 for the completed job.
Out of interest have you called Mapei technical support to ask if this would invalidate the guarantee they offer? Would be interested to find out.
By using two different manufacturers I cant imagine they'd guarantee it at all, but to me it's a no brainer, how can it go wrong
If it's fitted correct then it would be ok but I find the plumbers leave too much Silicon on the top edge & leaves you with a lip at the bottom of the tile.
I don't find that an issue, maybe because I've explained to all the plumbers I work with exactly how I want the classi deal fitted and so far so good🙂
Tanking price
Tanking and Wetrooms
Flintstone,
Lou,
Flintstone,
Lou,
