Currently reading:
Hair Line Cracks In Tiles
Discuss Hair Line Cracks In Tiles in the Canada Tile Advice area at TilersForums.com.
cityone
Hi lads, tiled a complete bathroom about 10 months ago (floor + walls to ceiling) and customer has been back in contact to say that some of the tiles have cracked, i went to see them and right enough there is a very fine crack line on some of the tiles, i must have done about 150 floors and this is the first one i,ve had to return to. I use the same method every time, (6mm hardie backer, glued, screwed and fiba tape on joints) told the customer that i will return tomorrow and he informed me that more cracks have appeared, i feel as though my work and system is tried and tested so is this a problem with the substrate floor??? any advice would be welcome, thanks in advance.
Reply to Hair Line Cracks In Tiles in the Canada Tile Advice area at TilersForums.com
Hi! I'm looking for some advice, I have laid some SLC (Mapei 1210) in our conservatory in preparation for tiling. A couple of days after there's a lot of very fine cracks which have appeared, you...
