Discuss Tiling Timber Floors - Preferred Method? in the Australia Tiling Forum area at TilersForums.com.
billthetiler
Hi all,
I do a lot of my work for a bathroom fitting company and the fitters constantly discuss the best method for dealing with wooden floors. I was brought up on 9mm WBP screwed every 100mm and primed, but I am now leaning towards anti crack matting. Others use Kudos Aqua4ma or Hardibacker. Any preferences guys? I am open to suggestions!
Dhtiling
463
Alaska
Ditra, strata mat, spiderweb2, permat, anything is nicer than carrying boards up the stairs. Nothing wrong with hardi though.
billthetiler
Thanks lads, I was in the ply camp just like Protiler 68 without incident for 30 years but we had a couple of loose tile situations last summer on 2 separate jobs, different fitters and different tiles so that's what made us look around for alternatives. I may try hardie. Can you bring floors back to level by varying bed thickness? Do I need to prime substrate or Hardie?
P
p4ulo
Hardie for me too.
No need to prime your subfloor (wood) as you will be laying some tile adhesive down under the boards before you screw them down. Yes, you can vary bed thicknesses to help levelling, but be careful when screwing it down because you don't want the boards to warp to the shape of the dips!
I've started sponging off and priming Hardie once fitted as advised by other users on here, no problems so far!
H
hmtiling
No more ply for me. Never had a problem with it and done 1000's m2 with it.
Also, like marmox with ufh.
SJPurdy
Personally I prefer Hardie to "no more ply" as I feel it is better if there is cupping on timber floor boards (the bumps and hollows of the cupping get filled with cement based addy when fixing to give a solid bed). However if under tile heating then Wedi, Marmox etc give better heating performance; they're also much lighter and easier to cut, but more expensive!
Spud
I used blanke permat recently and like it ,it is similar to the old eml mesh but a 21st century version
Ian
So it did used to work then lol ?
Still does work, so long as it's 15mm or thicker but, why would you when there's thinner products that do a better job. Get yourself out of the stone age and move with the times. You're making yourself look very stupid by continually arguing the toss and going against everything the manufacturers recommend, if you end up having to defend a failed floor in court one day, you'll get laughed at when an industry professional looks at it and sees the 6mm ply base.
Reply to Tiling Timber Floors - Preferred Method? in the Australia Tiling Forum area at TilersForums.com
