Discuss Travertine With Ufh in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com.
Greg K
Hi All,
I have 15 m2 of travertine on concrete floor. Part of that will be with electric UFH.
I want to put insulation for whole area, then wire, then tiling, grouting and sealant. White flexible adhesive.
Do I need anything else?
Thanks for any advice.
Q
Qwerty
Would you uncouple when using insulation boards Geoff ? .. Just curious..
Personally I do yes. I know many fixers and manufacturers (including Marmox) are content with the insulation boards providing the decoupling and it does without doubt serve this purpose perfectly, but for the belt & braces approach I always do. :)
Greg K
Thanks,
I know about insulation and slc, but can you tell more why decoupling membrane.
J Sid
What wattage kit are you fitting?
Is it for feet warming only 100W or 150W wire are you trying to put some heat into the room with a 200W wire?
If the first then no uncoupling membrane is needed imho. 200W then possibly you could but I wouldn't.
Dave
1,000,000
Co.Durham
Good thinking , 200w .. It might well be a conservatory or similar
Reply to Travertine With Ufh in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com
