Discuss Can Anyone Offer Advice On A Rookie Mistake? in the Australia Tiling Forum area at TilersForums.com.
donwheelay
Hi All,
First time poster in need of assistance.
Its been a while since ive tiled anything, and today I have proudly finished tiling a bathroom in a project flat which I have purchased as a fixer upper.
I had finished my days labouring and returned to look at my handiwork beer in hand and noticed one of the tiles had 'popped out'.
I sought advice on some forums and to my horror realised I had forgotten to prime the wall.
I tiled straight on to plaster (there had been old, and i mean OLD! tiles on the wall before hand which looked like they had been there forever.) using unibond anti mould bathroom adhesive. I have not yet grouted between the tiles.
What are the possible consequences of me having not primed the wall? None of the other tiles seem loose in any way - alas quite the opposite, they seem really well set and like theyre not going anywhere. However i dont want anyone to be sat in the bath and have a tile fall on their head or at worst the whole wall of tiles come crashing down.
I would be grateful for any advice or tips which anyone could provide me with. If it comes to it ill take them all down again - but obviously i also have no desire to repeat two days of tiling and if there is anything i can do to salvage what ive already done it would really set my mind at ease.
Rob
U
Unused Account 1
If theyve set and gone off ,you got away with ,also when you grout will bond it all together ,
gamma38
1,058
Bedford
I would say you have answered your own question... You wouldn't want any to fall of with someone in the bath. If one has already come loose!!!! That said you may be lucky and the rest stay firmly stuck.
Mr Tiler
Read halfway through the o.p... Read this comment, get that tile back on the wall and grout up, if tiles pop off while your grouting replace them and ensure they are fixed before you continue, the ones that dont move are there for good lol
bcd-87
Hi All,
Rob
Hi mate
Is the wall stud or block ?
I employed a handy-man a few years ago to tile a large bathroom wall he "forgot to prime "
a day later I shut the clients bedroom door and in doing so the bathroom next door begun to rain metro tiles !!! That was a stud wall.. The grout will help but as @Dan said don not rely on it...
donwheelay
Hi guys,
Thanks so much for all of your responses - but there seems to be a bit of a difference of oppinion on the matter! So i will add a bit more info.
I have tiled around a bath which is sat in the corner of the bathroom. Standard size bath and tiles go up to just shy of the ceiling.
Ive checked the tiles again this morning and no more have come loose that i can ascertain (ive checked at least 20 of them) also they are quite small porcelain tiles (10cm x 10cm). They do seem like theyre going nowhere.
The walls that i have tiled were both plastered and one side goes on to block work and one goes on to stud work neither of the walls which the bath is fitted onto has a door attatched. The door is on the opposite corner of the bathroom going off on a diagonal. I have not re-plastered the walls as they were quite smooth except for a few dings here and there. The plaster will likely have been there since at least the early 90's looking at the 'style' (if you can call it that!) Of the old bathroom suite.
When the tile came loose yesterday it did not fall out, one end of it just kind of 'popped out' by approx 1cm. The adhesive was still a little damp and quite gritty underneath as if it were semi dried.
I think thats about as much info as i can give but if you have any other questions, please do ask.
Thanks again for all your help.
Kind Regards
Rob
bcd-87
Hi guys,
Kind Regards
Rob
What adhesive did you use rob ?
donwheelay
Hi there,
I used unibond a tub of unibond wall tile adhesive and grout with anti mould which the guy at the store assured me would be perfect for a smallish job........
On one
Mmmm, a few things....
Tile adhesive is made for fixing tiles,
Grout is made for grouting tiles,
So you wouldn't fix tiles with grout would you? for all that certain Co's manufacture 2 in 1 Adh/grout combo's
it's not a great idea.
Fixing porcelain tiles with this type of adhesive?
not a great idea either,however small the tiles may be. The adhesive should have had better 'grab'
qualities.
Can't understand why the shop didn't sell you separate adh and grout,unless your advice came from
Homebase,Wickes,B&Q,etc,etc
donwheelay
qualities.
Thanks for the thoughts.
Perhaps in my naievity i went to B&Q as ive bought many things from there over the years for various projects and theyve always turned out fine.
Ive tiled walls and floors in the past with stuff ive bought from B&Q, the walls i cant comment on the current status of as ive long since departed those properties, but i tiled the floor in my parents conservatory 8 years ago and thats still going strong.
I did make a mistake in my earlier post - the tiles are ceramic and not porcelain - does that make a difference?
Ive checked the tiles again just and they really do seem to be stuck firm. Im still in two minds about what to do but they do seem ok.
I have not yet grouted however, would you suggest i purchase an alternative product for this? And if so what?
Thanks again for your help.
Rob
Reply to Can Anyone Offer Advice On A Rookie Mistake? in the Australia Tiling Forum area at TilersForums.com
