Discuss grinding terracotta tiles to even surface in the UK Tiling Forum area at TilersForums.com.
mikethetile
you can sand them with a floor sander
start with a very coarse grit and work your way up to a very fine to remove scratches
do not wet as this will make a slurry which will clog the paper
its a very dusty job and floor sanders are not really a diy tool , i would find a local that can come and do it for you
E
enduro
Thank you for this link- that may help a lot!
No problem, we are here to help, but these guys are truly experts in stone restoration, and they are world wide so they could probably put you onto a guy in your area. Lets us know if you get it sorted. :thumbsup:
DHTiling
Cheers Enduro....Another happy member sorted by a tilersforums trusted advisor....:thumbsup:
lucius
You cant realy grind or sand terracotta as you will take of the fired skin which protects it, if you did you would have to seal them with something pretty tough but the colours would be different. Have you tried to take one up because if it has been laid that badly the may come up easy.
Lucius
L
Lauri Marder
Thank you Lucius-
They won't be easy or possible to take up, they are pretty firmly set and one would damage the surrounding tiles if one tried. Also too many are problematic. Thanks for the advice about the fired 'skin' of the tile_ i did not know that.
Lauri
lucius
If I read it right you say the job is in Venuzela, ime assuming that these tiles are not that expensive to buy if so how about smashing the dodgy tiles out, just hit them with a big hammer in the middle and they should break without disturbing the adjacent tiles and replace with new.
Just a thought.
Lucius.
A
anthony123
Thank you Lucius-
Lauri
Hi, what was the solution to this? I have the same problem in an old condominium here in Thailand. Uneven surface, coated with years of pitted, wax and dirt that make the tiles really dark and ugly. We also thought of grinding them to even them out and perhaps give a more modern look and then seal them with some product.... even thought of polyurethane paint as a sealant!
Anyway am desperate for any good solutions if there are any!!
Cheers,
Tony
Blarney stone
Cheers,
Tony
:) don't use a poly sealant they need to breathe. they're designed to be porois so that they can keep the kitchen cool before we had refrigeration the floors would be slopped with water to create cool area for storage of meat etc. If its just wax you can remove the wax and they I'll clean up. There's expensive stiff called oxi gel but I have been using cheap oxi stain remover for laundry and it has done an amazing job even stripping off old tile paint. Where edges are raised you could grind them down or you can use terracotta coloured epoxy to fill a ridge so it slopes and fill the big chunks missing. This advice I got from floor specialist but the epozy does discolour horribly by dirt so I don't recomend it in areas where you will be walking regularly. Its really hard to just fix one tile but if its broken its not difficult and you can reset the odd one here or there. You can also use actual terracotta and a bit of lime to make a cement that is not going to spall them or create damp to fill gaps this doesn't discolour the way that the epoxy does but it is difficult to get the right mix and the right colour but if you can get terracotta clay without sand in your area to match the tiles ...I can't remember the ratio to be honest you might have to experiment with samples that's what I did. I think it was six parts clay to one part lime putty and then I used the clay powder to top it dry so the top was darker as the lime is pretty pale. Then seal them with a breathable sealer not polyurathane. Wax and linseed oil although recommended I find they attract the dirt badly. These floors in the old days would have been washed down every year around the 19th of may traditionally and scrubbed with a hard deck brush and sand which wore them away slightly to a soft finish. Its no harm to remove the top layer so long as you seal them with a breathable sealer or if you want to wax them fair enough. But wax builds up and about twice a year or so traditionally they would be cleaned with amonnia to remove the wax and rewaxed. Don't use any acidic cleaner on them as that will eat away at the brick and when you wash the floors use a dry mop to take any water off as if it sits on the indents it will make the indents deeper. When these floors were made it was expected that you would sweep them daily. Scrub them weekly and refinish them regularly when needed. They're not like a glazed tile that you can expect to stay like a dinner plate for years. they are more like hair they have to be daily taken care of. And even replaced and reset when needed. If you reset them use a sand lime base because that is much easier to redo and cement is too rigid..if these were ever reset in cement anywhere that temperatures change or moisture changes then the cement which cannot move can cause cracks and lifting. so always use lime and sand which is a soft base that allows for swelling and is also a joy to lift a wonky tile out so easy and replace in future.
Blarney stone
If you grind them you will take off the crust as such and will give the a different texture and make them more porous not something i would adv is this something you have inherited ? :pete
They're not really made with a crust. Not like a faced tile. they're like a brick all the way through. If they have a face like a quarry tile or a glaze then yeah don't grind but terracotta is generally all the same the whole way like a flat brick or a porous jug ... They're also designed to be porous so they you could use them to cool the kitchen in times when we didn't have a fridge.:) and most likely the finish has already worn off at this stage through wear and tear so grinding won't be worse. If they were perfect obviously don't grind them. But if they're already pitted grinding will make them better. They were also designed to be hand ground with sand ever year by a housewife. So they can take a grinding. And they look nice as they grind down over time by wear and scrubbing. They need to be sealed though with a breathable sealant and if you want to use beeswax you can but that needs to be removed and redone every now and then.
Reply to grinding terracotta tiles to even surface in the UK Tiling Forum area at TilersForums.com
Teejay
