Hardiebacker v's Ply confusion
H
Holohana
Hi all, hope you can settle some confusion ive got.
Ive got a job where im doing some floor tiling and the builder is boarding out the floor for me but called today nd amongst other things asked to see how I would do it.
Told him I’d use Hardibacker, he was using 6mm ply himself and always does, and id lay this on a bed of flexible adhesive then screw every 300mm.
The area is 85m2 so comes in at just under at £1,000k for the boards plus addy plus labour. He balked at the total cost and said he’d just use what he’d already planned to do.
My labour was dirt cheap to lay the board, £100 a day, as got a free week and could do with a week of simple screwing.
The board going into 8 units all the same size so cut one lot of board and you’re away for the rest so really easy.
Joiner quoted £10m2 for laying ply plus ply so I’m well cheaper on labour and frees him up to crack on with other stuff on the development.
Now this is where the confusion starts.
When laying Hardibacker, 6mm on floors as per the spec which to start with I think is too thin, it states that you need a bed of adhesive applied with a 6mm notched trowel and then screwed.
My question is when laying simple plywood over boarding why don’t you need to use a bed of adhesive in that instance?
Technical at Hardi said its to make sure you don’t have any air gaps under the board which would allow movement and cause problems.
I get that point but couldn’t the same happen when laying ply?
Thanks in advance for what im sure will be compelling reasons why you do for one but not the other.
If ply your right about a screwing every 300mm so the bulk of screws will support it, Hardie backer I Personaly don't put screws in every 300mm I use about 8 and put extra sbr with the addy between hardie and floor, even forgot to use fixing's once never had any problem's
The adhesive helps with any undulations in the floor but also aides with making the cement board more rigid. The ply is usually 12mm plus so is fairly rigid to start with. You haven't said what the original substrate was but personally I wouldn't lay on 6mm ply on a floor that size.
If this 6mm backer is onto chipboard then fine, no addy reqd. I have never had problems, but on T & G it's different story....Gaz
floor is chipboard on 2 x 2 joists. All small units totalling 85m2 with the max area being 5m2. Office toilets x 2 in 8 seperate units so not one massive area.
Builder is using 6mm ply so in theory he should be using adhesive too then?
I thought 12mm would be rigid enough, guess you could still have gaps though?
Ive never had problems either but always been domestic, not commercial and not 85m2 polished porcelain!!!
Fair point cover all your bases on this one Holo....Gaz
If you are not happy with the builders prep work...then say so to him...if he won't change it..then don't do the job...coz if it does go wrong it is you who will be to blame as well.......
laid out all the options to him so he is aware and the pros and cons of all alternatives.
He's done plenty before so he knows what he is happy with, He knows what addy ive quoted for and will be using so he knows i know what im doing.
12mm ply isnt an option for him!
Or ask him to sign a waver, stating you had disagreed with his preparation .....Gaz:yes:
i guess you can therefore use 6mm hardibacker because the adhesive bed vreates the rigidity then?
Waivers, are they actually worth the paper they are written on?
Sounds like the old story, builder is trying to save money by giving you at the least a concern. I am with the others in that if he doesn't prep the job the way you want then it is not worth the hassle. However if it is small units and you are happy that the floors are rigid enough with 6mm ply then that is your call. The 6mm hardi would be more rigid than the 6mm ply but it looks like he doesn't want the extra expense.
The area is 85m2 so comes in at just under at £1,000 for the boards plus addy plus labour. He balked at the total cost and said he’d just use what he’d already planned to do.
:47: He balked, and then disregarded your professional advice? I'd walk. Really, I would, and that's not even considering the price is nigh on ludicrous. I wouldn't ever do something which I couldn't leave a warranty on with good conscience. If I was short of work, and I needed the job anyways, I'd make the customer sign a waiver, which would stipulate that I couldn't be held responsible for any potential troubles caused by the substrate.
Holohana,
sWe,
Holohana,
sWe,
