Discuss Sealing top of tiles????? in the UK Tiling Forum area at TilersForums.com.
garybadger
Why has the joint at the top of the tiles and where the ceiling meet, not been grouted in anyway? Why leave the gap?
Gazzer
IMO I find that caulk is far more flexible for this situation than any grout. Silicone in the corners and caulk around the ceiling.
Stewart
IMO you should never grout an internal corner, as it will always crack! You should always use silicone on internals and where it meets the ceiling, you should use caulk if it's to be painted.
Created on iPhone.....
P
Perry
IMO you should never grout an internal corner, as it will always crack! You should always use silicone on internals and where it meets the ceiling, you should use caulk if it's to be painted. Created on iPhone.....
You could paint water based silicone when I used to use it has it changed or have they stopped making it ?
Joshua
Perry - Water-based silicone is NOT silicone! It's latex caulk or equivalent. Much lower strength and flexibility. Can't use this for applications requiring water-proofing.
Reply to Sealing top of tiles????? in the UK Tiling Forum area at TilersForums.com
