Discuss Causes of cracked limestone tiles with UFH in the UK Tiling Forum area at TilersForums.com.
jasonh15
Hi
We have a problem with linear cracks in a newly laid limestone tiled floor.
The screed substrate at around 65-70mm thickness was laid by the builder onto the foundations, then an extra thick layer of insulation - required by building control due to extra glass in the room. The screed has wet under floor heating in it.
Then limestones tiles were laid around 4-6 weeks (he says 6 weeks but I think it more likely 4 at most) later onto flexible adhesive provided by the tile supplier.
The area is approximately 10m long and 7m wide going down to 5m.
The UFH was not ramped up and down by the builder before he laid the tiles but it was gradually eased up after the tiles were laid over a period of about a month. The work was done last summer.
The cracks started to appear as the weather got colder in the winter and the UFH was on most of the time at its max temperature. They travel in both directions and span multiple tiles, They start as hairline cracks but the limestone does flake away and the crack opens up becoming more obvious.
One interesting thing is that the cracks only appear in about 2/3 of the floor area. In about 1/3 of the floor area where a different flexible adhesive was used, because the amount supplied by the tile supplier ran out, there are no cracks whatsoever.
The builder is blaming the tile suppliers adhesive, because he says it is to be expected that the screed will crack with UFH but the flexible adhesive should take the stresses of the cracks.
However the tile supplier is saying the screed must have cracked and no flexible adhesive can prevent cracking of the tile if there is significant cracking of the screed.
The builder had attempted to take up a line of cracked tiles, to inspect for damage to the screed, but had to abandon it because of the risk of damage to the screed and UFH and the surrouding good tiles. He also though that the bit of adhesive he took up, which is said he will get analysed, seems very rigid with no feeling of elasticity too it.
Any thought on this would be much appreciated?
Would flexible adhesive that had set feel rigid or should there is a "flexible" feel to it?
It is possible to get adhseive chemically analysed to establish whether it is what is was expected to be?
With UFH should we expect screed to crack and if so should should th3e flexible adhseive handle this?
Should it be possible to perform spot repairs on the tiles/screed/adhesive without damaging the rest of the floor - is my builder just using the wrong tools?
grumpygrouter
It would have been beneficial to have laid a decoupling membrane like Durabase or Ditra underneath your tiles. Limestone is very fragile and the UFH and temp changes, along with the settling of the screed has transferred all the stresses through to your tiles. A decoupling membrane would have been a way to prevent this.
Flexible adhesive doesn't feel "elastic" unless it is something like BAL fastflex. Flexible means it will "move" more at molecular level when stresses are applied to it because of the polymers they are manufuctured with, not that it will bend and squash.
diamondtiling
I agree with everything you have said Russ but even if he did all the above I think problems would still have arose because of not having the UFH on and allowing it to reach max temp and then cool before tiling.
:thumbsup:
P
peckers
you say the floor was tested prior to the screed being laid, the heating should have been turned on and run with the screed down and allowed to cool down and be turned off prior to tiling the floor. It sounds to me as if that now the heating has been used that the screed has cracked in places and it has gone threw to the tiles. It sounds like the screed has expanded once the heating has been turned on, and the spf if this is what was used couldn't keep up with the expansion rate of the screed, the heating should have not been turned on for the first two weeks once the tiling was complete and then only put on a couple of degrees and then slowly increased day by day.
You can remove the grout around the edge off the tile using a oscilating tool with a grout remover blade in it or buy a hand one if you like then you can break the tile out and inspect the screed. you shouldnt damage the heating as it is in the screed?
If the builder is blaming the adhesive company then the adhesive company can come and take away a sample and have it tested, to make sure the right adhesive was used.
The questions i would be asking is.....
1 why was the heating not turned on and commisioned with the screed down before tiling?
2 is there expansion joints in the screed around the perimeter of the room?
3 is there expansion joints for the tiles around the perimeter of the room?
4 why was there not a de-coupling membrane used, was one suggested?
5 The exact adhesive and grout used?
jasonh15
thanks for responses so far - answers to peckers questions:
I'll be asking the builder/tiler but he was pushing to get the job finished quicker.
Yes there is supposed to be - I believe there is a 25mm polystyrene border
Yes for 2 also
Not suggested. I only came across this type of thing when googling for background information.
Unfortunately I do not know this - on te invoice it just says flexible. Manufacturer was Weber and Stonell were who we bought it all off.
The heating in the screed. I will suggest the method you have proposed for removing individual tiles.
Reply to Causes of cracked limestone tiles with UFH in the UK Tiling Forum area at TilersForums.com
