Discuss Fixing sink to tiled stud wall in the UK Tiling Forum area at TilersForums.com.
Smithy153
Hi guys,
I'm fixing a sink to a tiled stud wall. Wall is 12mm plasterboard. Just wondered what best practice was. Tiles are white ceramics.
I was going to use plaster board wall plugs but know its best not to put any stress on the tiles. Any advice would be greatfully received.
Cheers Smithy
Dan
Admin
1,318
Staffordshire, UK
It goes without saying really. www.365drills.com, and say you're from tilersforums.com.
Though, if you twisted the chuck on the drill a few times before pressing the button, you'll score a small hole in ceramics easily.
Once you have scored at the glaze enough to steady your drill, press and release the trigger a couple of times, really low revs, and then once you feel it's through the glaze, don't press on it, go slow, and ease in the hole. As they say. lol
Once you have the hole, I found the plasterboard plugs to be best for stopping the strain going on the tile. So go for it.
Good luck, and pics would be cool of the finished job. :)
faithhealer
in a pefect world, there should be a baton of sorts to screw into. But never is of course. I take it , that is has a pedestal to take the weight, so I usually add a few blobs of silicon a well as the screws, which as you rightly say, shouldn't be tight on the tile.
Always angle them of course so you can get your screwdriver in!
Or fit then little bracket thingys, two screws in each!
brian c
furthermore,if you can get to the wall behind the sink(a cupboard maybe)then you could fix a baton to screw into once you have drilled the holes as Dan says.The bosch blue drills are also excellent to use for this 6mm .
grumpygrouter
Hi guys,
Cheers Smithy
You can get specific sink:thumbsup: fixings for fixing to stud walls. Think I got mine from B&Q a few years a go.
Smithy153
Cheers for the advice. Don't fear about 365 drills Dan I've got my kit ready and raring to go lol. I've been on here long enough to know that ... Lol. It has no pedestal and no baton to fix it. Also have no access to behind. Ill have a look in b&q for those fixings you mention grumpy
Time's Ran Out
Hope the basin is not too big - with no pedestal/no support in the wall/onto plasterboard - your asking the tile adhesive and tile to take a lot of weight.
Timeless John.
Deleted member 1779
On my bathroom projects I throw away the supplied fixings.
Then use M8 COACH BOLTS to get maximum strength.
Sinks are bloody heavy and rather than place a loading on the tiles I drilled holes into a fixed baton and then fitted the threaded bar though the holes. Then tightened at the back with NYLOCK nuts.
Plaster boarded over the top.
Drilled 16mm plugs out of the tiles and then fitted over the coach bolts.
Holes are drilled as 16mm plugs to slip over the coach bolts.
Result:
PROJECT ONE
The coach bolts (above) are fixed with two nuts. One to hold the sink against the tiles via a washer. The next nut holds the tensioner for the hanging half pedestal.
Its a lot of weight to hold onto tiles so M8 Stainless steel nuts and bolts are used.
PROJECT TWO
Even this sink has a solid bolting system. (note to self - should have used Nylock here)
Tip - Dont over tighten nuts when fixing until you are sure everything has settled like tile adhesive.
Its the wooden beam behind the tiles and plasterboard that should be taking the weight of the china, the pedestal, the taps and of course the water.
Sinks can be bloody heavy! - And expensive....
If you drop them / break them / crack or chip them during installation then its unahappy customer time. Even the accessories can add to the dead weight.
simhopper
Result:
PROJECT ONE
PROJECT TWO
Why not use a fisher fixing basin set, Metal washers and cermaics dont mix....Nyloc nuts, Do you live near a railway line:lol:
Deleted member 1779
I'm not a big fan of the Fisher system.
But its personal choice. Yes I should shield that washer with rubber really.
Reply to Fixing sink to tiled stud wall in the UK Tiling Forum area at TilersForums.com
  • Sticky
