Steps
charlie1
Can anyone give advice on tiling steps with quarry tiles. If the step does not but up to wall on each side then i would require a corner tile at each side, but then the setting out of the other tiles would be dictated by this which would mean there is a high probability that one of the middle tiles would have to be cut to fit.
Im windering if i need the corner or the bullnose tiles and if i could just make my own with my bridge cutter?
What do you think guy's
Hi Charlie, here is a set of steps that I did last year. It might give you some ideas.:thumbsup:
http://www.tilersforums.com/attachm...ing-external-steps-2007_1126mcculloch0007.jpg
grumpy , could you not have got full tiles across the steps, even if you stretched the grout lines a bit , not critisizing just wondering mate.. :thumbsup:
I normally try and lose the difference in the grout gap, so that all tiles look the same size.
Could you I not make bullnose and corners from normal tiles using a very good quality bridge cutter?
I did look at this but the grout joint would have been overly large in my opinion, something like 12 to 14mm if I recall, but to be honest I can't remember now. I felt that cutting the RX's gave a more pleasing result. Customer was delighted so that is the most important thing.
does look quite dandy tho even with the slim tiles at the end, makes a nice finished border effect :yes: judging by the rest of the property it was in need of a nice finish
Fine set of steps there Grumpy..haven't done any yet but I know where to go for advice if I ever do:grin:
no sweat grumpz , its a good job mate !! :thumbsup:
Steps
Tags Tags
steps usa
charlie1,
andy-p,
charlie1,
andy-p,
