Discuss Would you consider this quality work? in the Canada Tile Advice area at TilersForums.com.
Toni
Hi all,
I'm hoping you can give me an opinion on the quality of this work as I'm having a bit of a nightmare - the floor is finished and although the tiler came very highly recommended it just doesn't look high quality to me.
I've had my 65m2 floor tiled with 80x80 porcelain tiles and 5mm grout lines and the job has been more or less finished so I've paid the majority of the bill.
The tiler grouted but didn't do a very good job of the grout, he pulled too much out in places so it was much too deep. He came out and checked and agreeded it was poor so he said he will regrout when he gets time before Christmas. But now I've had time to clean and polish the tiles down properly I've noticed quite a few things look wrong and I'm wondering if they are what you would expect from an expert?
The grout lines were supposed to be 5mm but some are 6mm and some are 7mm, lots of the corners are out by a few mm and when you look down the grout lines they don't look straight because of the different spacing and wonky corners. Where you have a 7mm grout line coming off a corner next to a 5mm one it looks pretty bad.
Also some tiles are higher than others. I think it's called lippage. It not enough to trip but its about 1.5mm difference so you can see it with your eye.
I've added some pics below of the issues. Am I being too picky here or is it bad enough that I should I be asking for it to be rectified somehow (although I'm not sure how it could be fixed without starting again as if you fix one alignment issue it will just create another one)?
To be fair the guy was ill during the job which held him up so perhaps he was just having a bad day/week at the office. I don't want to hang him out to dry as I'm sure he wouldn't have done anything deliberately but I don't think I can live with these issues. I notice them every time I go in the room now.
If this was your floor would you complain and if so what action would you expect from the tiler?
Thanks ever so much for you're help
Toni
IMG_5776.JPG IMG_5777.JPG IMG_5786.JPG IMG_5822.JPG IMG_5851.JPG IMG_5856.JPG
I
Italy
I too many times I'm sick, but that does not mean I have to work evil !!!!
Here the problem, could also be tile uncalibrated, but the customer should be warned. grouting and flatness, by chills
Dan
Admin
1,318
Staffordshire, UK
I'm sure the cut edge is on the inside on the two top tiles in this image?
The tiles may be sized-poorly, as Antonio says above. Perhaps you can measure some?
But some of the blame has to be down to the employer, you!
You need to make sure you get a few estimates, and check references for each, see examples of work, etc.
Just going for the cheapest tiler, or the one the bloke in the pub said to use, doesn't cut the mustard these days. Far too many chancers about.
Haven't read your post, didn't have time, but looked at the pics.
I'd not be happy with it. But whether it's tile quality, tiler quality, or owner of the floor just going for the cheapest, doesn't matter - The floor isn't brilliant.
Edit: just looked again - is that bottom right tile bowed something rotten down the left hand side of it??!?! - or is it the stella kicking in?
Terry the tiler
Looking at this I wouldn't be too happy but before I say too much about the work, I have laid tiles (mainly cheap bnq/wickes/homebase) before and the tiles vary in size sometimes as bad as 2/3mm. This is a nightmare and sometimes you have to bin spacers off to compensate.
It looks to me like he didn't use spacers so this may be the case.
The deep grout joints he has no excuse and if they are cut tiles on the inside there is also no excuse.
Maybe when you call him back round you should ask the question he may be able to tell you why.
Time's Ran Out
A picture from distance may show more.
Who supplied the tiles and where did they come from?
Toni
Hi,
Thank you so much for the replys,
Dan, there is no cut edge in that picture. They are full tiles aligned like that.
I've checked a few tiles and they seem exact to me. I've got a few boxes left so I'll check them in the morning but the ones I've checked so far look ok.
Regarding price, he definitely isn't the cheapest - I went with who came with the best professional recommendation. He was hired to replace a faulty floor that was supplied to us by tile choice.
Tile choice were very good and replaced the tiles for us with new ones and agreed to pay for half the fitting cost once the job was finished. They would probably have paid for it all but I didn't push for that, I just wanted a nice floor and was happy to contribute to get it sorted without too many arguements.
This guy is one of the top two guys tile choice recommend in their shop. They say he normally goes over the top to get things perfect which is why I picked him. They didn't just say that to save money as they always recommend him to their customers without complaint. He his known to be a good tiler.
That's why I wanted to check if the pics look bad to other tilers as i was expecting the work to be amazing - it's come as a real surprise!
Toni
Here are some more distant pics. If you look down the length of grout it seems to wobble. It's not uniform.
Also, he used spacers when I was there - 5mm ones. But maybe he didn't use them on some bits.
I'm fairly forgiving, any mistakes won't have been deliberate. But when your expectations are so high it's terrible to have a floor that looks so bad.
Ps...apologies for the crocs in that picture. Ha ha
623
Leeds
Usually in the tile sheds, the 'best' tiler that they tend to recommend the most, tends to be the bloke who spends the most, or sends them a good flow of gullible punters.
He might also bring them butties on a morning, donuts on a Friday, hangs around for an hour drinking the free coffee etc...
By no means do they tend to be the best tilers though
only my opinion, obvs.
Time's Ran Out
There are issues. But how much is due to the tiler and how much is what he has to work with in tile quality is not totally visible . He should have of course refused to fix them if they were so bad, but it's difficult to criticise the supplier who gives you work!
Reply to Would you consider this quality work? in the Canada Tile Advice area at TilersForums.com
