Which adhesive, concrete floor.
N
newtile
Hi there this is my first post I’ve been reading the forum for a while now , doing research for my first tile
project. I’m going to tile my living room. At the moment I’m getting more and more confused about which
adhesive to use. My tiles are 300 x 300mm
The floor is concrete.
Can I tile straight onto the concrete or should I use a primer first? And for the adhesive I know I will need to use one that is cement based . I see that bal and mapei gets mentioned a lot here but bal looks very expensive. Not sure whether to use flexible or non flex. Also the rapid dry and normal dry.
Will the rapid dry too fast for a beginner? I read in another post somewhere can’t find it now that if you use
normal dry time, your tiles will sink in the drying time, is this true?
I’m veering towards the mapei brand as I know where I can buy 20kg bags in London , Could someone please suggest which one I should go with if mapei is ok. Or maybe another brand.
phil
Mapei is a great adhesive, do you plan on having UFH?. Personally I always use a flexible adhesive, usually a rapid set on floors but as this is your first project and assuming you can keep people off the floor for 24 hours you may find a standard set more to your liking. I always prime concrete floors just to consolidate the dust.
As above, prime floor with a suitable primer for the adhesive. I would also use a flexible standard set adhesive to give yourself more time.
Good advice already. For me flexible, slow setting, cement based adhesive (I don't like being rushed so rarely use rapid set!). Always prime concrete floors, if you are getting mapei adhesive, use mapei primer g.
Ill back the standard setting adhesive for a beginner and yes keep everyone off it for at least 24 hours as above.
everyone for your replies, No I will not be installing UFH. I have taken on board all your advice, so I will prime and use a normal dry time flexible. Won’t be starting for a few weeks yet . Yes I hope I can put some pictures up to be proud of when finished.
phil
newtile,
kevg,
newtile,
kevg,
