Discuss What's the best cordless angle grinder in the Canada Tile Advice area at TilersForums.com.
mike1979
I use a ryobi plus1 I bought it without the battery as I use two ryobi drills that came with two batteries I bought the grinder for 60quid had it for a while and it's fantastic best buy Ive ever had I use it daily for sockets and bits in kitchens as it's quicker than setting up a mains powered
Stef
Switch it on and horrible burning smell
Jonny that doesn't sound like the brushes.
If the brushes are worn & don't connect then there won't be a kick out of it.
Pop them out & you will see how much they are worn & take it from there.
judge
1,078
Burning deffos not a good sign.Take it back to place it was purchased.You should get a lot longer than 9 months work out of it.Personally i think the dust does loads of damage to the grinders and as Radim said ,compressed air gun every now and again should help the life of the grinder.:thumbsup:
G
Gazzer
When i do any maintenance on grinders, drills or wet saws, the 1st thing I do is blow around the motor with compressed air. Its amaing how much comes out, cant be good for it at all.
1,068
we work nationwide .
I have three makita 18v cutters, ( keep putting them down and then not being near one, three works great for me and helper! ) had a few small probs ,but soon repaired under warranty . though i now fancy a variable speed one now, any ideas if there is a cordless variable speed model out there ???? and also i only cut mosaic mostly........
Chalker
1,058
Tadcaster
Reply to What's the best cordless angle grinder in the Canada Tile Advice area at TilersForums.com
