What adhesive thickness should i use?
P
paulprior
Hi
I have 3 bathrooms to tile, floor and walls, how do i know what thickness of adhesive should be used, i see the notched trowels come in many different sizes
the reason there's alot of differnet size trowels is because there are different scenarios. so what are your:
tile sizes
tile type
Wall type
Wall Condition
Floor type
Floor condition
and thats just for starters.:lol:
Hi
the walls are plasterboard, the floors are timber covered in ply, the tilles are 600*300*10, floor tiles porcelin and wall tiles ceramic
I would back skim your floor tiles and use a 10-12mm floor trowel..
Depending the thickness of your wall tiles about a 6-7mm trowel
Hi
Just for info, why does it make a difference for the tile thickness?,, should all floor tiles use 10-12mm?
Paul
Hi
Paul
No, depending the the size, if you have a small floor tile then the floor would need to be as flat as possible but a smaller trowel size would probably be required
paulprior,
Rich,
paulprior,
Rich,
