Hi there
Currently doing the final prep for a wet room, should be ready in approx 6 weeks.
Wall sizes are as follows
2.2m wide x 2.2m high - 4.8sqm
2.2m wide x 2.2m high with a window 1.2 x 1.2m - 3.4sqm
1.8m wide x 2.2m high - 4 sqm
Walls to be done in metro tiles 10x20cm, window reveal to be tiled along with corners mitred with no trim.
Floor 1.8m wide x 2.2 long - 4 sqm
Floors to be done in 50x50cm with envelope cuts to the linear drain
Location is IP13 0SP.
Would appreciate a very approximate cost, i will not hold you to it, i just don't want to waste your time traveling to quote.
Kind regards
Adam
Wetroom 16Sqm Tiling Job Metro
Tiling Jobs | Find a Tiler - Post Tiling Work Here
Adam18Spring,
Adam18Spring,
