Discuss Up to skirting base boards or under? in the DIY Tiling Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Warthog
Hopefully just a quick question. Kitchen skirting base boards are already on the kitchen walls and have been installed over the top of existing ceramic tiles. When the ceramic tiles are removed there will be a gap under the skirting boards.
1/ Should I cut the existing skirting boards with a multi tool to accept the new thicker tile?
Or
2/ Should I leave the skirting boards and tile up to them?
I imagine option 1 would be more useful as I can install with a gap for expansion all around the room but what would you guys suggest?
Warthog
Ok, that will definitely look neater as I skimmed over artex wall covering, I’ll just tidy up the walls behind the skirting boards with plaster and install a smaller and more modern skirting board
Reply to Up to skirting base boards or under? in the DIY Tiling Forum area at TilersForums.com
laattaana
