Underfloor Heating, Timber Floor Boards and Durabase
simonb43
Hi,
Have been to see a job over the weekend and have some concerns.
Piped underfloor has been fitted to bathroom floors, timber floor boards replaced and durabase matting has been fitted. However, this has been fitted with PVA only, and i have already told the customer this is no good, it need to be fitted with tile adhesive.
Also, should there be backerboards fitted to the floorboards before the durabase is fitted as i would always board a timber floor with these prior to tiling. Also the underfloor heating is approx just below the floorboards so would the heat be too intensive ??
Basically, if i had been there before the tiling was started i would have advised the customer to do the following,
fit backer boards, glued and screwed ( possible ), fit durabase with flexible adhesive, fit tiles with flexible adhesive then grout. Is this correct ????
I would like to think that my advice is correct. Any answers to the questions please ??
Not a DIY John, just wanting confirmation that I'm correct. Surely that's what this forum is about !!!
As you didn't answer my post no. 2 it would be difficult to establish to which level of advice and depth of information you would require.
I would like to consider myself a professional tiler John and am just asking if I'm right with what I'm saying. As stated earlier I would board floor first, fit durabase, then tile, with flexi adhesive.
simonb43,
TJ Smiler,
simonb43,
TJ Smiler,
