Discuss Top Tips and Trick with Metro Tiles in the Canada Tile Advice area at TilersForums.com.
I
Italy
Ahah
268
Wiltshire
Mark wall out.
Realise you have marked the wrong way so cutting In the socket will be a nightmare.
Smear lines on wall so you don't follow those by mistake.
Mark new lines.
Stand back look at how messy the wall looks and have a coffee/***/tea break to draw the job out.
Look at wall again and forget which markings you are working to.
Realise you are working on a Saturday the golf club is open and you should be having 9 holes instead
Simples!
(Side note... this is only an excuse if you have started with a hangover)
Andy Allen
1,318
Gloucester
Can't say I enjoy using metros....but a jobs a job....
There's no easy way to use them just try keeping the bond in the corners...but don't be that anal about it if it means avoiding slithers....use 8mm trims....use a decent non slip adhesive, get a level line round the room and work from that ..no need for buttons....and I always use a new squeegee when grouting to get as much of the grout of as possible
Mark wall out.
Realise you have marked the wrong way so cutting in the socket will be a nightmare.
Mark new lines.
Simples!
You sound more like a sparky Laura! :p:p
Reply to Top Tips and Trick with Metro Tiles in the Canada Tile Advice area at TilersForums.com
  • Article
123 Year Old Johnson Tiles Factory to Close Down Causing 110 Job Losses 123 Year Old Johnson...
