H
hutchi
A customer is looking at using 600 x 900 x 12mm porcelain on walls of a new extension. Weight of tile is 14.22 Kg each that equates to about 26.5 Kg/m2.
What is the limit that various substrates can cope with?
Looking at breeze block walls for some of the area that may have first coat of plaster (not skim) or plaster board, stud partition for the rest, going up to max 3m high (angled ceiling). Will also be using backer board in shower area.
Any help is appreciated as to what guidance needs to be given.
Expecting to use normal rapid set flexi for the area,
