Discuss Tiling on walls after old tiles removed in the America Tile Forum area at TilersForums.com.
56
Huddersfield
Do you think it would be ok to tile over this wall after the removal of the original tiles?
Kastar UK
163
Leigh GtrManchestet
Its cheaper to skim it than throw loads of adhesive at it , quicker to tile if can gauge
Is a bit rough i wouldnt want to tile it
Doesnt need to be polished skim for paint can do it yourself
56
Huddersfield
The other side is worse the above wall is papered as I believe the wall isn't good enough for painting
Dan
Admin
1,318
Staffordshire, UK
Should be able to knock those adhesive blobs off from the previous dot and dab tiling (considered of the worst type of tiling going). Then apply adhesive using a trowel next time and you wont get those off so easy.
What's your end aim here?
Reply to Tiling on walls after old tiles removed in the America Tile Forum area at TilersForums.com
  • Article
123 Year Old Johnson Tiles Factory to Close Down Causing 110 Job Losses 123 Year Old Johnson...
