Discuss TILING MOSAIC TILE ON 8MM FLEXIBLE PLYWOOD in the Canada Tile Advice area at TilersForums.com.
Hello all thanks for all the useful suggestion, I am particularly interested at the solution with the 6mm insulation board, will it bend without any cutting or slices, will a 10mm needed to be sliced? Which kind of insulation boards are recommended? Thank you very much.Thank you all for the reply and suggestions, there is not enough
Space for a 20mm board, probably can get away with max 12mm, i tried a sample of flexible plywood, the original plastic panel is all cracked and a replacement can’t be purchased, will try to load the pics
View attachment 94989 View attachment 94990 View attachment 94991
Thank you for the quick replyThe curve is so gradual that you may get away without having to score the 6mm board and any board thicker than this. A 4mm board would not need scoring.
Numerous makes available- Wedi, schluter, marmox, jackoboard.
Where are you?
Reply to TILING MOSAIC TILE ON 8MM FLEXIBLE PLYWOOD in the Canada Tile Advice area at TilersForums.com
