Discuss TILING MOSAIC TILE ON 8MM FLEXIBLE PLYWOOD in the Canada Tile Advice area at TilersForums.com.
ggman
36
Romford
Thank you all for the reply and suggestions, there is not enough
Space for a 20mm board, probably can get away with max 12mm, i tried a sample of flexible plywood, the original plastic panel is all cracked and a replacement can’t be purchased, will try to load the pics
A4D085EC-303D-416F-A20B-C4F7EF47D5E5.jpeg 75D54C1B-06CA-4012-B104-086CC49B3F05.jpeg B87E59DA-4EC3-4440-8AF0-4A7E05FFF783.jpeg
MTiler
Just get some normal Wedi and slice half way so it curves to fit. Smooth of with rapid set and scrim tape
ggman
36
Romford
View attachment 94989 View attachment 94990 View attachment 94991
Hello all thanks for all the useful suggestion, I am particularly interested at the solution with the 6mm insulation board, will it bend without any cutting or slices, will a 10mm needed to be sliced? Which kind of insulation boards are recommended? Thank you very much.
ggman
Q
Qwerty
The curve is so gradual that you may get away without having to score the 6mm board and any board thicker than this. A 4mm board would not need scoring.
Numerous makes available- Wedi, schluter, marmox, jackoboard.
Where are you?
ggman
36
Romford
Where are you?
Thank you for the quick reply
I am in Romford
ggman
Reply to TILING MOSAIC TILE ON 8MM FLEXIBLE PLYWOOD in the Canada Tile Advice area at TilersForums.com
