Discuss Tiling behind a wood burning stove in the Canada Tile Advice area at TilersForums.com.
P
Paul Cockhill
HI
I has a wood burning stove installed in my house last year, the stud wall was replasted with heat resistant plaster but a crack has still appeared and I think the best thing I can do is to fill the crack and tile behind it.
I have been to Fired Earth and found some good heat resistant tiles.
Has anyone any thoughts or suggestions?
thanks
Paul
42 Peasedown St John Wood burning stove cracks in plasterboard 001.jpg 42 Peasedown St John Wood burning stove cracks in plasterboard 003.jpg
P
Perry
Try these tiles great for a fire place
Broken Link Removed
I wouldn't thought plaster would be any good for heat cement board or fire board would be the thing to use
P
Paul Cockhill
Thank you for your reply. I cannot be certain what was put on the wall but I was assured that a heat resistant board was put on before it was skimmed over. This skim has cracked so I thought by tiling it it will look good and be protected from further cracking
P
Perry
You may need to cut a little hole in it to see what the board is because if the plasters lose the tiles might end up on the floor with the plaster attached to them
Reply to Tiling behind a wood burning stove in the Canada Tile Advice area at TilersForums.com
Teejay
