Tiling a splashback above bathroom basin
angedup
I'm a DIYer who has just managed to tile above the sink in the ensuite bathroom - an easy job as the sink top was level and flat and I used this as my first row of tiles and tiled up from there with a batton on the side
I now want to do the other bathroom -
width = 5 10x10 tiles height = 2 or possibly 3 rows
BUT the basin in this bathroom is shaped at the top
legend
Where should I start my tiling to get a good flat finish at the top and make my cutting job as 'easy' as possible.
Any advice welcome. Thanks
is the basin screwed to the wall? if so unscrew to a desired distance ie enough to allow the tile and adhesive bed to sit behind but not too far so that the screw comes out, tile behind the basin allow to set, grout and rescrew basin back to the wall...hope this helps
chris
Certainly an idea I hadn't thought of. What will stop the tiles slipping as the adhesive sets if there is nothing for them to rest on?
thanks
yep!
the way to do it is unscrew the basin and tile behind,you will do it in 1/2 the time it would take to cut around it and it'll look much more professional
if the tiles aren't coming up from the floor you can attach a baton or use baton stands
thanks
what adhesive were you planning on using? if you can buy mapei p9 from a supplier this is a white powered adhesive that is mixed with water, it has a very good initial grab i use this alot of the time. if you press your tiles into the adhesive in a slight twisting motion and hold in pplace for about 20 seconds the tile should not slip. if you are using a tubbed adhesive i would batton behind the basin to support the tile.
chris
It's a ready mixed tub of ahesive grout in view of the fact that I'm a 1st timer and not doing that much tiling. Will go and investigate the basin now to see if there is room for my batton - pedestal might be in the way!
:smilewinkgrin:
you can batton down to the level you need the tiles to go i.e 1 inch below the lowest point and use the basin to hold it in place by tightening the screws to hold when the adhesive has cured(possibly day after) loosen screws and remove batton.
chris
Thanks CJ Ceramics.
Still just a little bit worried about the look of the whole thing. My width of tiles overhangs the baisin edge by about 3 cms on each side. Think it will look ok with this overhang extending out below the top of the basin?
Perhaps I'm being too fussy in view of my lack of skills . . .
Thanks CJ Ceramics.
when tiling a splash area above a sink basin i usually allow the tiles to overhang the outside edge of the basin unless i am using an edging profile
in my honest opinion i think that leaving the oerhang will look fine but make sure that you set your first tile in the middle of the basin.
chris
Bathroom Tiling Advice
Unsolved
angedup,
doug boardley,
angedup,
doug boardley,
