Guest viewing is limited
Tiling a bathroom
adam_starkie
Hi,
I am new to tiling, as you can probably tell when you read further onto this message, anyway here is my problem.
I just had a new bathroom suit fitted, and cant afford to get a tiler in to tile it for me, so i have to get it done myself.
The problem I have is that I have tiled the back wall, with even cuts either side of the wall, so it look cemetrical BUT...
when i go to put a tile onto the corner of the wall to start the new wall and row of tiles...the tiles are a MILE out, they dont join up close to each other and i am stuck. the back wall which is tiled now, is straight, using a spirit level ..but no matter what I do the tiles will not join up from the side wall behind where the taps are to the tiles on the wall that is already tiled. What can I do about it ?
Any advice / info regarding this will be extremly appreciated. Thanks in advance.
-Adam
Work out your tiles so you have a good size cut each end. Batten up,lay field tiles and when you come to cuts each side cut each tile individually and leave a bit of a gap for expansion and Silicon. It is rare to find walls that are plumb.
I see what you mean.
Put a batton on the wall to create a straight edge then tile away from that and then put the cuts into the wall ......from the batton to the wall ... ?
meaning that the cut at the top of the tile might be longer than the cut at the bottom of the tile ? - sorry to sound so thick here, its just been chewing at me for ages ...plus the window is quite near to the wall that is miles away from the tiles
That`s right. Never rely on walls being straight. Always use a spirit level to set battens and work off these. Good luck.
Whats the best way to assure that the tiles have stuck to the wall sufficiently? - the walls are so out of shape it worries me slightly. Maybe its first time tiling worry I dunno ....Do you guys check that they are on good enough, if so, how do I do this ?
PS
I tiled the first wall yesterday so its been round about 24hrs since they where put on.
just a tip mate,if at the end of the wall you have around a half tile to cut,use the other half of the tile to start the next corner off (the return),that way keeping to what looks like a full tile,rather than half a tile,then a full tile which will look silly,best off making your cuts slightly bigger,then you can trim if needed,rather than find you cut to short and therefore waste a tile
PS
when you fix your tile,dont just push it into the addy,push and TWIST it into place,then they will hold properly,also it may be worth inquiring what thickness the tiles are,and what sized serator (notched trowel) you are using
Thanks for that mate, it makes sense then im not wasting tiles cutting out the halves ...Cheers!
The tiles are 8mm tiles ...I am not using a trowel ...I am just shoveling it onto the wall ..and some on the tiles? But using a thing I bought from B&Q to score the addy so its not just flat to the wall ...cant remember what the tool is called
Maybe a Newbie mistake ?
you should just have bought a cheap 6mm notched trowel,that way you spread the addy evenly.You only learn if ya ask questions mate.Sorry but i am going to have to go off line now,sure some of the other lads will help ya if you need it
Best of luck
No Probs matey! - Appreciate all the advice!
I go out tonight and buy a 6mm notched trowel ...I still have 3 walls to do ...I think ill go home tonight and have a tug at these tiles ...if Im not happy, scrape it off and re-tile it ....they should have bonded ok tho, if not I know what to do.!
Tiling a bathroom
Bathroom Tiling Advice
Unsolved
UK Tiling Forum; UK
adam_starkie,
adam_starkie,
adam_starkie,
adam_starkie,
