Tilers Tiling And Tiles
. If laying on a wooden floor then I recommend at least a 9mm board with a flexible adhesive and grout. When tiling onto new plaster, at least 2 - 4 weeks should be given for the plaster to dry, this then requires priming. with plasterboard this should be primed at least twice and takes roughly 3 days to cure.
Can you clarify on these bits...????
I think the second bit is referering to skimming over plasterboard (i.e three days for the plaster skim to dry, not the primer) but just not that well put across.
I'm not sure The Wright Tiler wrote the peice but is posting it for members benefit - some good info but not well explained in places
I was sat wtching the thread/post come up, if Andy was typing it he should be in a typing pool, super quick:thumbsup:
theres a lot of work gone into the above posts
well done mate
i hate to to be picky
is 9mm ply enough to take the flex out of a wooden floor, would reccomending plastic ply to newbies be better
overlaying with ply was the best system available but if better products are developed specificaly for a job
wouldnt we be better to promote this
i have noticed a marked increase in ply prices over the last few years
coupled with a marked drop in quality of the ply
far eastern ply is compressing when screwed, not a small area where you drive the screw under the surface but saucer sized indents where the inner laminate is compressing under the stronger outer laminate
also voids in the inner laminates,
when you drive screws in you feel the difference , its like screwing plasterboard now
too heavy on the trigger and your through to the bottom laminate
this ply is unsuitable for overlaying floors as its likely to compress under the weight
this ply is turning up everywhere as decent ply is in short supply and very expensive
anyone who cant spot the difference could be storing up trouble for the future
i would reccomend not using ply for overboarding
Some good points mates, This has been brought up a few times now not least by Dave in fact and i happen to agree. Timber is one of those materials that you cannot be sure where it came from, it's not like buying a branded product which you can know and trust, it comes from all over the world and the only way of telling is by have links to a local timber supplier who knows where his stock comes from rather than a national who may but from hundreds of sources. Ply isn't the problem it's the supply of good ply that is, as you say:thumbsup:
TheWrightTiler,
TheWrightTiler,
