Wall and Floor Tiling Standards BS 5385 Part 1 and 2 British Standards, ISO Tile Fixing Standard.
Welcome to TilersForums.com, the place to discuss all tiling standards whether British Standards in Wall and Floor Tiling, BS5385, or ISO European Standards for Tile Fixing.
Tiling Standards
Wall and Floor Tiling Standards for the UK: British Standards in Tiling.
Discuss Tile weight limits on walls in the Tiling Standards area at TilersForums.com.
Raccus
uk
ok so i read a post from Paul C on weight limits, that went:
Wall Substrate Maximum Weight of tiling per m2
Gypsum Plaster 20Kg/m2
Gypsum Plasterboard Direct (without a plaster skim) 32Kg/m2
Plywood (WBP) Up to 30Kg/m2
Lightweight Tilebacking Boards Up to 40Kg/m2. Dependant on the type and thickness of the board.
Glass reinforced Cement Sheets Up to 50Kg/m2. Dependant on the type and thickness of the board.
Gypsum Fibre Boards Approximately 35-40Kg/m2
So, quesiton is..... I have fixed marmox backer boards to plaster skimmed walls. Marmox say their boards can hold 100kg/m2 if mechanically fixed, or 60kg/m2 if fixed using adhesive. So if you have large marmox boards (120x60cm) adhesived to plaster skimmed walls, what is the weight limit? Do the boards increase the weight limit? I cant see the whole board peeling or falling off the wall beyond the 20kg/m2 weight limit of plaster.
Is there any guidance on this, or is it down to logic, eg plaster holds 20kg/ms and thats it, no matter what you put on it. And are not a majority of tiles over 20kg/m2 anyway?
H
hmtiling
Without the mechanical fixing you've reduced the hanging weight by the weight of the board and adhesive. Fix the boards with washers and scrim the joints
Tile Shop
As andy says. Weight of marmox is 3.6kgs per sqm. Plus the adhesive to stick it around 3kg. The skim still has to support the weight of everything fixed on top. Without mechanical fixings into the stud or block behind, you have a tile weight limit of only around 10 kgs plus more adhesive/grout. But put the correct fixings in, and you can use the marmox to its full potential.
H
hmtiling
It's Harry btw :)
F
Flintstone
The washers stick out too far if there not tapped in correctly. If you used ‘spankers’ where you hammer a pin in then you need to tap the fixing in so it’s flush with the board before putting the pin in, if using plug and screw with metal washer then just screw it in tight so it’s flush. I haven’t heard of overboarding plaster solely relying on adhesive to stick a marmox board, no reason not to add fixings is there? Unless there’s complicated wires and pipes etc in the wall perhaps.
Raccus
uk
I added some fixings today in the areas that i hadnt yet tiled, and as Local tiler suggested, i hammered them in a bit more forcefully so they stuck out less. Better. Should have just gone with that first up, its takes an age to adhesive the board on. Those spanker fixing are super fast!!! But part of the reason i adhesived was because i had a long shower tray (1.7m) and the two adjacent walls ran out, so tried to thicken adhesive as i went, to reduce this. Anyway, done now! Hope its ok!
Thank you all for the helful replies.
Reply to Tile weight limits on walls in the Tiling Standards area at TilersForums.com
Hi all - I have some small format ceramic tiles (10x10x1cm) to use as a splash back around the...
I started removing the tiles in my bathroom today and the majority of the plaster has come off...
Tikkaaa
uk
Tiling Standards
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
