Discuss Tile water absorbtion experiment in the Canada Tile Advice area at TilersForums.com.
C
Canyondust
I have read the thread title, let us use that as the test name. The points are that the test (thread title) are not representative of paragraph 1.
That is the discussion. Component test (and it is useful for comparing a single component tile (non glazed)) versus system tests.
Dumbo
Do you know what I put my hands up your right . I must of misread when he said I plan on seeing how water tiles absorb
C
Canyondust
How is that relevant in the slightest to the conversation ? Whatever he proposed to do changes nothing to the logic behind the comments.
Your not aiding the thread at all.
Q
Qwerty
@Canyondust put it this way, the purpose of the test was 'I plan on testing how much water tiles absorb' and the results were that the ceramic tile soaked up water and kept soaking it up, the porcelain tiles hardly soaked up anything. End of
Your posts appear to be of no help to this thread in the slightest and I am totally confused as to what your point is. @jcrtiling has made some valid points and your point about 'room temperature' has to be my favourite. The test was performed at this temperature as this is the temperature that tiled rooms in a house tend to be.
Are you a tiling professional?
Have you experienced real life situations of failure tiled substrates in showers/ wet rooms?
Do you understand the construction method of wet rooms?
The reason I ask is I think you are looking way past the point and simplicity of the test and looking to deep into it.
C
Canyondust
That is correct as far as that test goes. The test shows the maximum water absorption at room temperature. A very long way from 'end of
Your posts appear to be of no help to this thread in the slightest and I am totally confused as to what your point is. @jcrtiling has made some valid points and your point about 'room temperature' has to be my favourite. The test was performed at this temperature as this is the temperature that rooms in a house tend to be.
My point is that the moisture absorption when installed is likely to be different of this specific test for the reasons given previous. It is not a system test which is what one should be concerned with.
The points I make are very relevant as installed performance is what one should be concerned with.
The temperature is related to expansion of ceramics and stones which typically absorb more water as they get hotter. The temperature of a tile in a shower may not be at room temperature if water is directed and bathrooms change in temperature.
No.
Yes
Yes. I built my second earlier in the year.
As mentioned I am explaining the limitations of the test and how one may interpret the results. So my sympathy with the intention of the test is embedded in my posts.
C
Canyondust
Twice it was suggested I was either selling tiles, working for a tile company.
My posts are purely related to science and engineering and to open a helpful debate. I'm genuinely interested in the installed performance of tiling systems and the associated components and longevity; a deeper interest stemming from reading posts here for close to 1 year.
Sadly the feeling of unwelcome is strong.
Hmtiling - thankyou appreciated. Just bad timing.
Reply to Tile water absorbtion experiment in the Canada Tile Advice area at TilersForums.com
