Discuss Tile edging problem in the UK Tiling Forum area at TilersForums.com.
Shaz
Is there a flexible tile trim I can use between carpet and floor tiles, the join will be curved..customer wants room half tile and half carpet..any advice as to what I can use?
DHTiling
Hi shaz and welcome..
You could use a product like this....and then use carpet grips to hold the carpet in-situ..against the trim.
Uniform Bending Of Profiles With Radius Perforations
Certain Schlüter profiles with radius perforations are available for the protection of contoured edges. The perforations make it possible to adjust the profile to the contour of the covering edge. To achieve quick and neat bending of most profiles with radius perforations, use the specially designed Schlüter-RUMA bending machine. For full details of profiles with radius perforations, and which are suitable for use with Schlüter-RUMA, ring Schlüter-Systems Ltd on +44 (0) 1530 813396. The picture shows an example of how a Schlüter profile can be easily contoured to fit a neighbouring curved surface.
DHTiling
No problem....maybe you could post a few pics of the finished job...:thumbsup:....what type of tiles are you using...anything nice..?
Shaz
Not decided yet, needed to see if the problem could be solved first...but now..the sky's the limit!! Will post pics when job is finished.. Cheers!
Reply to Tile edging problem in the UK Tiling Forum area at TilersForums.com
