Tile Cutter Now Leaving Jagged Edges
perky416
Hi Guys,
First time tiler here part way through tiling my bathroom. I purchased a Sigma Series 3 Max tile cutter which at first made an amazing cut, it was almost perfect, however after about 20 cuts i am now getting jagged edges on my tiles and chips every so often. Unless a chip occurs the finished edge of the tile is pretty good, its the material that sits behind the finish that isnt clean and protrudes the cut edge by a couple of mm.
The tiles im using are the Kamber 600mm x 300mm, 9mm thick from Topps Tiles, they are porcelain with a polished gloss finish.
Is this normal?
Should I buy a new blade or just crack on with it? Im just concerned that it will affect the separation at the edges.
All help appreciated.
No I didnt realise i had to. What would you recommend? Do you think i should i buy a new wheel and make sure i oil it?
Thanks.
Polished gloss (glaze?) on porcelain?
They'll need a light score - one only.
Some types of these tiles are simply impossible to get a very clean cut on.
Experiment with different pressures and you'll find the best one.
After you put the tile into cutter check you have the bar at the proper height as it does move slightly thru the day as you use. If it is set up correctly usually find it cuts sublime. I learnt by my mistakes.
perky416,
Leroy Brown,
perky416,
Leroy Brown,
