The best primer and Adhesive for anhydrite screed
Jase-tiler
Hi, I have a 60sqm floor to lay on Anhydrite screed, I am using 800mm x 800mm porcelain tiles and Ditra matting.
What is the best primer to use, and adhesive to fix Ditra matting.
And finally what is the best adhesive to bed the tile with.
[h=1][/h]
Use an anhydrite compatible adhesive. Here's a list of manufacturers, although it's not exhaustive, and the primer from the same manufacturer to fix the ditra. On top of it you can use your usual flexible cement based adhesive. Also a flowchart that helps you ensure all the steps are followed
Broken Link Removed
[DLMURL]http://gypsol.co.uk/media/1170/guide-sheet-4-flooring-flowchart.pdf[/DLMURL]
Don't forget you might need a movement joint or two in an area that big.
ring me if you need any other advice 07966651006
I've just finished an anhydrite screed and I used tiles master anhyfix with their prime plus. I'd reccomend anhyfix to fix ditra then use time master setaflex (slowset) to fix the tiles to ditra.
I'm not supposed advertise specifics but I was I would say the same...
Thanks for the advice I will follow it.
Also what is the process involved installing a movement joint?
I've done quite a few anhydrite screeds now & everyone I've done I've used TileMaster AnhyFix.
I've not fitted Ditra on top but if I was I would be using the exact same process as above.
If there's a movement join in the substrate then follow that through the tiles, either fit a movement join or do it yourself.
Stefs do you ever leave grout line out and Silicon it to allow more expansion
I've only ever done it once on an anhydrite screed, had to break it over the door threshold as it was showing a very small crack & didn't want to take the risk.
I would pick a calcium sulphate screed over any other now as there's no hassle tiling to them.
Meant to say, it's funny how quick you get used to these screeds.
Looked at a job last week, 4 floors, 2 downstairs on top of a Gyvlon screed.
Speaking to the builder & he was convinced it was a cement based screed till I showed him what needs done to it.
I think he was a but dubious what I was telling him, got a phone call a few days later to say that everything I had told him was exactly what the screed guy told him.
Only problem I picked up was that the screed guy told him it was 1mm per day drying time, I had to explain that that information only goes to 40mm then it's 1mm every 2 days.
Jase-tiler,
Lee@emctiles,
Jase-tiler,
Lee@emctiles,
