Spot the ball
field tiles underneath the mosaic border do not line up with field tiles above on toilet wall. not much in it but you can see i think unless it is angle of picture .
not sure how that could happen if full tile set off right side off vertical border and working away.
there is also a very thin slip of mosaic to right corner but this cannot be avoided unless mosaic sheets cut and stretched if working full mosaic off right vertical mosaic.
nop
Grain of the mosaics?
ok can see joint of mosaic just off lining up with field tile below and above but the starting point is just right of vertical mosaic . mosaics are not made to line up as can see half bonded after first tile would line up.
could argue that joints could have been stretched to avoid tiny slither cut i suppose but we are talking fractions.
grain of mosaics are different but cant see this on original pics.
one should not be expected to tear them off a sheet and refix individually.
Spot the ball
The D,
Time's Ran Out,
The D,
Time's Ran Out,
