Discuss Shower Tray Drain And Membrane in the Tanking and Wetrooms Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Craig Hamilton
hi just wondering if I should put some silicone or some type of sealer between the membrane and drain retainer ring thingy image attached any advice would be much appreciated
thank you
craig
Craig Hamilton
It's a tuff form tray and homelux membrane I have not put anything on it yet so don't seal it in any way?
Craig Hamilton
I haven't added any sealer just the tile adhesive under the membrane thanks for the videos
Meddler
Good instructional videos. I havnt done a wet room yet but it seems to cover the practical points in a clear and concise manner, the principles which can apply to any system. A good resource.
gamma38
I have used the homelux matting quite a lot. Providing you take it right into the outlet before you make any cuts then just the mechanical holding of it by the plastic part is pretty good. I have never had one leak or fail.
Reply to Shower Tray Drain And Membrane in the Tanking and Wetrooms Forum area at TilersForums.com
Apatel
