E
essexsi
Hi all,
Will soon be tiling the floor of a walk in shower with a concrete screed floor. Sort of a wetroom floor. The drain has been fitted and sticks out proud of the concrete screed, but has dust cover on it at the moment. The square metal drain cover bit has been left off. Should this bit be fitted before tiling or after?
Am I right to assume that the drain should be the lowest point of the floor.
At what height should the metal cover be fitted then -
1- below tile height
2- at tile height
3- above tile height.
Do I just leave a similar grout line around the drain cover?
Sorry for the vague description, not sure what the metal bit is called!!! Its the posh shiney plug hole cover!!!!!
Cheers for any help. Si
2- at tile height
