setting out time dry lay?
2020Tiling
I seem to be spending a lot of time setting out floors, wondering if theres a quick way ? after prepping i normally dry line a few rows then tweek them to get the best line .. this could lead me to dry lay most of the floor so it doesnt look off angle . how do you lot find the correct line if the rooms not square ?
i look at a room and see which wall will follow your eyeline, i then square everthing off that wall using a long stright edge..
what if theres no walls to come off, i mean if the kitchen has units fitted all round
Put your level against the kitchen unit doors reaching to the floor and pencil mark, I would start from the longest set of units but like everythink play it by your eye, if it don't look right, it aint..
i tend to stand in door ways , and eye up whats going to look the strightest line, if its a long set of kitchen units , take that as being stright, work your tiles out from that line and away you go..
my advice is carry on spending plenty of time setting out, you would be mad to try and rush it ,after a while it becomes less of an issue as experience tells you where the best place to start but for now take your time use your guage stick
spot on :thumbsup:
Drylaying has its place ie a small bathroom floor
Anything else then square off a long straight wall and staff out.
2020Tiling,
widler,
2020Tiling,
widler,
