self-levelling screed for wet room floor?
G
grassyknoll
To prepare the concrete floor of the wetroom I'll need to get it level enough for tiling. Can anyone advise me on:
a) will self-levelling screed be suitable and if so up to what depth?
b) is such screed really 'self-levelling' - does it need any work to get it level after being laid?
c) is it better/easier/cheaper to use than ordinary concrete?
d) should it be tanked?
I'll need to cover an area of approx 3m2 and most of the area will require a depth of screed up to 2cm.
Ta
Mapei ultra plan maxi will do 30mm in one go...I would tank it especially with bieng SLC'd..
3 sq mtrs will not take much doing...how are you forming your falls to the drain.?
Well, I'm told it's possible to form them in the screed itself, or failing that in a new concrete layer. Do you think it's feasible?
You can actually get a 20mm thick tray former from wetdecs and then screed upto that...the falls will be alot better then..
Its the tuffdecs 2 tray...have you installed the drain area yet..?
The drains are already in situ, courtesy of the previous incumbents here. There's a gulley in the existing concrete floor over which was the (very) old shower tray. I can post a couple of pics if that will be of any use?
Wish someone had told the builder I've been working for about pre formed trays before his attempt at screeding the shower area:incazzato:
2 x pics herewith. One of them shows the existing width of the room, but that will change when I take down the partition wall and move it back.
grassyknoll,
DHTiling,
grassyknoll,
DHTiling,
