Discuss Sealing a Slc garage floor prior to painting in the Canada Tile Advice area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Si2111
Need some advice please on sealing Slc.
Not sure if I'm in the right place for this but worth a try.
I have recently Slc a garage floor and want to paint over it as the finish but I'm not sure what to seal it with prior to painting as it has a very porous/dusty finish, any advice would be very appreciated.
Si2111
Not all slc can be used as a wearable finish. Which one did you use?
I used Mapei Ultimate Leveller 1210,my first time using a Slc so wasn't sure what to use so didn't go for the top end stuff did it on a budget so prob wasn't the right stuff to use I'm guessing.
H
hmtiling
I don't think that is suitable . Tilemaster external leveller is suitable and reasonably priced . You could prime and put a coat of that on top . unsure about how thick that would need to be but @Glynn will know
Reply to Sealing a Slc garage floor prior to painting in the Canada Tile Advice area at TilersForums.com
Lowpaul22
