Rubi DN200 wet cutter.
Jeffrey4670
Hi, today my new Rubi DN200 wet cutter arrived from TradeTiler. I also ordered a Marchrist Blade with it. I noticed that the table top slants down at on end, which makes the blade not cut at 90. Anyone out there with a D200 noticed this. When you look at it in front elevation you can see it slant. Jeff.
email dave at trade tiler and ask him he will tell you. i have the bigger 1 the d200 and its ok. this 1 has a slpit tilting table where as the dn200 is a single table.. so mabe its the design of it...
I have a nd200 and mine seems to slant but hasn't bothered me, but it is a great cutter, bought the marcrist blade with it, still only use the rubi blade it came with.
Hi, The slant on the table top has got to be in design of the cutter, because I was looking at a ND 300 and it's very much the same. The ND300 is a massive cutter as compared to the ND 200. I assume it's for large format tiles only. Jeff.
To save you emailing me, I thought I woul post here instead 🙂
I have noticed it myself even on the ND-180 so I guess it must be a design feature
I have just brought the d 200 wet saw brilliat for porcelain, ceramics ad travertine but what about slate ?
The problem I see with this type of cutter and slate is the amount of residue cutting the slate will make. This will carry around and can clog the slot where the wheel is in the bed. An overhead rail cutter would be better but change the water often.
Jeffrey4670,
MTiler,
Jeffrey4670,
MTiler,
