Q
Qwerty
Guys, I think the OP is suggesting ending the top row of tiles with the trim so the top edge of the full tile has the trim on, therefore the 4mm edge will need say a 6mm trim (allowing for adhesive). I only assumed this as he said 'levelled' brick tiles.
Neither I nor the OP ever mentioned anything about using a 4mm trim.
Obviously if it is a cut tile, then your thoughts of a thicker trim apply which is common sense. If this is the case, it will serve me right for assuming it was just a top run of trim!
