Discuss putting a niche in an external wall in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
L
lmkitchens
Hi guys, looking at a bathroom design im doing and the customer has asked if I can install a niche behind the bath. Its an external wall.
Can this be done, obviously it can be cut out and a lintle installed. But what about sealing the cavity, what materials to be used etc.
Cheers, luke.
Ajax123
Cheers, luke.
that might require building regs approval as a "structural" alteration. Don't get caught out.... As for the rest.... No idea. :)
mattle40
Can you not stud the wall off? Obviously nobody wants to lose precious space but its gotta be a lot of hassle to do it by the book as you should with building control
L
lmkitchens
No space, putting the bath in a granite topped cradle and shoe horning in 2 x 600 vanity units. Thats my lot!
gamma38
Could you not just build a feature wall incorporating said niche or niches above the top of the bath on the existing wall, I did some recently that were only 80mm deep in the same situation, using studwork. Sort of surface mounted boxes if you like, but posh. They looked good in the end and the customer got there design.
L
lmkitchens
Its something I may have to look at. Just its making its way into the area ofbthe bath which I was trying to avoid ):
widler
Not really dave, if he takes bricks out and just sticks a 1x1 frame at the back of the brick not into the cavity ,he would get a 4" or more niche.only small but enough for some soap :)
widler
Good god, really alan.
Thats total overkill on the planning department , bloody hell :)
DHTiling
I would not be doing it...
Diggy
Is the long wall of the bath internal ? If it was and there was a cupbaord on the other side you cut into that one maybe? Lot of work though for somewhere to put ones Loofer or shower gel :)
Diggy
Reply to putting a niche in an external wall in the Canada area at TilersForums.com
laattaana
