Gazebo
Hi all,
Hopefully this will be easy to advise, i have dark grey 600x300 porcelain wall and floor tiles to be fitted to....
1. 18mm overboarded Ply floor fixed every 300mm
2.Stud walls lined with 12mm marmox construction board and green moisture resistant plasterboard.
I am confused as to what needs priming prior to tiling, i have read many of the posts and threads with ref to this but still in a muddle. I am obviously going to use a Spf addy and a fast set Spf for the floor, and a flexi coloured grout(mapei probably) but do i need to prime/bond the cement board or only the plasterboard, and what about the ply floor.?
Tiles are apparently pre sealed (HTW sourced) any other tips would be appreciated, will post photos of job when complete, give you all something to laff at.
Cheers, and be lucky.
Gary:8:
Gary:8:
