Discuss Porcelain Tile Cutter in the Tiling Tools | Tile Cutters, Trowels area at TilersForums.com.
148
Carmarthen
Hi Everyone,
Thought I'd start another thread, rather than clutter my other 2 up! Which will hopefully be useful for any other newbies looking for advice.
Looking for a porcelain tile cutter that will cut the majority of tiles (approx. 600mm x 300mm x 10mm).
I appreciate I may need a wet cutter for some of the cuts (will hopefully be able to borrow one), but will this suffice for cutting the majority of my tiles:
Vitrex 102360TC 10 2360 50cm Heavy-Duty Tile Cutter: Amazon.co.uk: DIY & Tools - https://www.amazon.co.uk/d/Hand-Cutters/Vitrex-102360TC-2360-50cm-Heavy-Duty-Tile-Cutter/B002SH62KK/ref=sr_1_3?ie=UTF8&qid=1493284454&sr=8-3&keywords=tile+cutter
I don't need a super duper cutter, just one that works well.
Thanks in advance.
Dumbo
Probably your best bet is to ask the tile shop you got tiles from if they have a cutter they lend or hire out . If they do it would probably be a rubi or sigma . Most independents do this around my way
148
Carmarthen
It looks like we're going to be buying online.
I don't want to spend a lot of money, but it needs to get the job done.
The reviews for the above look okay, but I thought I'd check with the experts:)
I
Italy
Hi Everyone,
Thanks in advance.
With that, cut only the potatoes. But I, just an apprentice ;)
148
Carmarthen
Can you recommend a tile cutter that will do the job that I require, i.e. Cut 600 x 300mm tiles?
Ideally I don't want to spend loads, as it will get very little use after this job.
Would an option be to hire a cutter for a day and aim to get all the cuts done in one day (don't know if this is feasible)
R
Rookery
I know of only one place in my area that hires out a cutter - a Rubi 1200. If you don't want to spend around £300 on a Sigma, a Big Clinker is a cheap alternative. Although not the most accurate it's perfectly adequate for your average tiling job.
Reply to Porcelain Tile Cutter in the Tiling Tools | Tile Cutters, Trowels area at TilersForums.com
