Discuss No screw door stop on tiles with UFH in the UK Tiling Forum area at TilersForums.com.
E
ErnS
I need to fit a door stop on floor tiles with UFH. A couple of months ago I found a web site advertising a range of stops designed to be fixed without screws. Unfortunately I'm now unable to find the site. Can anyone point me in the right direction or recommend a no-screw door stop.
Alan.P
I can't think of a screwless option, only an overhead door closer type stop, sorry, got me stumped, or what about a skirting mounted stop ?
mike walker
try sticking it with gripfill or nomore nails that sort of thing and see if it works
E
ErnS
Thanks Alan / Mike - The door is to a bathroom and the stop is needed to protect a ladder towel rail. An overhead closer would be a bit over the top and a skirting stop would have to be too long to clear the rail.
If I can't find the suppliers web site or another screwless option I'll probably try the nomore nails option.
mikethetile
you can with care fit a stop if you purchase one with the dowel that sits in the floor
you will need masking tape around your bit as a stop to prevent the bit from going deeper than the tile, then stick it down instead of screwing down
the dowel will prevent the stop from moving
i used some non screw stops a while back on altro flooring, they had a sticky pad , once stuck down you couldnt move them not even by banging the door against them
brilliant
till the cleaners mopped water around them for a few weeks
then we got recalled to replace them with screw down type and mastic around to keep the floor water tight
they were supplied by the main contractor so i dont know where they came from but i havent seen any since
all the other door furniture came from lloyd worrall so id try them first
oogabooga
Mike, I think perhaps he'd still be worried about damaging the UFH (the dowel method). If so another option would be to use clear epoxy to stick it down.
Deleted member 1779
Let me offer you a solution.
The reason you want a doorstop WITHOUT a screw is because you are afraid of piercing the underfloor heating. (and I dont blame you )
Solution:
1) Cut a 16mm plug (or core) out of the tile. Only drill deep enough to disturb the tile. Do not drill deeper into the adhesive. It will look like this.
2) Carefully remove the adhesive underneath to check and see if you have exposed the pipe.
3) If you have not hit the pipe you can go ahead and drill down to install a standard rawl plug.
4) Place your doorstop over the plug then used an over-long screw to reach down to the rawl plug.
5) You should fit your nice doorstop.
What can go wrong?
If you are really unlucky you will have drilled out the core slap bang over the top of the pipe with no room for manoeuvre.
If thats the case you can either fill the plug with no-more-nails and fix the stop (but I doubt it will hold) or you can buy a wider doorstop and re-drill a new fixing point.
E
ErnS
Thanks for the suggestions guys. I still prefer the option of a specialised screwless stop and will continue to search for same - for a few days at least. If I can't find one then I'll probably try the clear epoxy and if that's not successful will try Richard's drilling suggestion - I already have a set of those fantastic Porsadrills so another opportunity to use them!
The only problem there would be that my UFH is a wired system and its buried in SLC. I suppose if I used a good wire detector I would be OK.
It's all a little bit frustrating really since before finding the web site I mentioned initially I was expecting to used a screwed stop and would have mapped the wire position before tiling so that I could drill without fear.
WHID to?
Would something like this help?
Pin Door Stop,Hinge Pin Door Stop,Pin Door Stop Suppliers,Hinged Pin Door Stop
I may have gotten the wrong end of the stick but this looks like a possible solution. Although I know you don't really want anything close to the hinge under normal circumstances (levers etc) this may be worth considering..
This supplier is in India (apologies) but I would have thought something similiar would be available over here....
Deleted member 1779
Thats OK. Drilling a plug out is a very permanent action so doing it would need you to be committed.. You would end up poking about with a screwdriver to remove the dried adhesive when exploring.
Yes Hindsight is wonderful on jobs like this! I wish I had mapped out all my walls and floors prior to covering them.
Having laid a full sandwich of self levelling compound, adhesive and then the tiles it was a mystery as to where the UFH pipes were buried....
K
keraldine
Not sure if I am getting the right idea but could you not put it on the door frame ? It will prevent the door opening as wide but will protect yor towel rail
E
ErnS
I see what you mean but it wouldn't sit very well on the grooves and shaping of the architrave moulding and with the leverage effect there could well be too much stress on the hinges or compressive damage to the door.
macten
Surely a skirting stop doesn't have to be very long if it is positioned close to the hinges?
cornish_crofter
Solution:
What can go wrong?
Taking this idea further, one option is to dispense with the plug and screw completely and sit the door stop in the tiled surface. Fix it down with some rapid set.
tile55
There is a product on the market called 'Stick Like S...' Yes it really is! no joke.
This stuff is seriously good for sticking things down when you don't want them to come up again, costs about £6 a tube.
If you have a door stop already then you can take out the screw and just stick it down.:thumbsup:
http://www.NoLinksToThis/sfd/i/cat/13/p4010913_l.jpg
Reply to No screw door stop on tiles with UFH in the UK Tiling Forum area at TilersForums.com
10 Tiling Tips for Fixing Tiles to Bathroom Walls = From UKTilingForum.co.uk There are a few...
