Discuss Newbie. in the The Welcome Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Anjumh
Hi ive been doing small easy subway tiling in kitchens. But keep getting let done by tilers in the area. So I decided to take the job on myself
Its a small bathroom using 600-300
Porcelain tiles. First what is the best
Cutter to use. The tiles aren't smotj finish.
Dumbo
Hi and welcome I use a sigma 3c3m for this type of tiling . It has a cutting length of 720mm which allows for tile cuts that aren't square
Anjumh
Hi thanks for the info looking into that model and a few other the only worry i have is the tile is not amooth its like a fipple effect so sid not want to damage the tile by chipping it. Been watching plenty of YouTube vids a
Anjumh
Whats the best way to cut a hole for the waste pipe approximately 32mm
Is there a drill bit??
acaciaguy
Hello and welcome. You can get a a tile hole saw for that. Erbauer do a 35 mm one. You can get a 32mm one. I tend to use 35mm to give a bit of wiggle room
Lou
Admin
Staff member
Welcome!
Anjumh
Hi can anyone suggeat the best way to level uneven walls before tiling
As one wall is out about inch an a half
Horizontally one wall flares out at the bottom
Reply to Newbie. in the The Welcome Forum area at TilersForums.com
Dawz84
