Discuss Manual cutter in the Canada Tile Advice area at TilersForums.com.
gamma38
Points
1,058
Bedford
Hi all, I am in the market for a new cutter, I don't want it for one particular tile or size but would only say it would have to cut 600mm. Wet saw is sorted so I'm good there. I have read all the threads on here but from what I've seen it is impossible to get any answer. Is it really just personal choice like it seems or is there one make and or model that really is head and shoulders above the rest??
I
Ian
What I say is, have a go with 2 or 3 to see which suit you best. Rubi tx700 would be one, a Sigma that will take a 600mm tile and maybe a tomecanic. Do you have a budget in mind? What manual cutters have you used before?
gamma38
Points
1,058
Bedford
I don't really have a budget in mind, I am at the stage of upgrading pretty much every tool I have and it's hit the card already. In the past I have got by with some average tools and some good, but all good makes everything that much easier. I have a rubi ts400 and a genisis pro 600. I have had a play on a tx and found it ok. Whats your take on single rail or twin???
I
Ian
Tx700 is my everyday cutter, brilliant tool. If I had the choice of single or double rail, I'd choose double every time, just easier to see the cut marks.
mattle40
Got to put my hand up for sigma here, since converting from rubi myself a year ago iv converted a few tilers now, when you see one work on porcelain it's a no brainer
Sigma 3bm is my everyday cutter
mattle40
I haven't had a go with a sigma, how do you guy's find the single rail and seeing your mark? No problems or a bit harder??
I can't lie at first it's difficult but you soon find a knack for it, first day I had mine it was a revelation!
And any points against a sigma for not seeing the cutting line
It more than makes up for in breaking power, cleanness off cut and it's capable of very small slithers
mattle40
Yes I would definatly recomend having a go.
It's a shame there aren't more sigma users as I think most people just automatically go for rubis because that's what you see in all the shops etc, I think if more people tried before the buy(ed) then there would be a lot more sigmas around
gamma38
Points
1,058
Bedford
I see them on fleabay, but is there any of the shops stock them?? I can't ever recall seeing them to be honest so I guess your comment about rubi seems pretty justified.
mattle40
I use a push model with the max handle so I can only speak for that model but it's very natural, easy to modulate pressure, nice leveraged and with a quick flick the breaker pops down from the scoring handle so it's very quick when u get used to it
As for stockists I can't rly help pal but I'm sure if you give sigma a call they can point you in the right direction
prceramics
rubi tr700 is a good cutter unless you cutting loads of porcelain its a bit cheaper then the tx but the breaker is not as good .
Reply to Manual cutter in the Canada Tile Advice area at TilersForums.com
