White Room
No chips here....
Discuss Lip clips and spacers in the Canada Tile Advice area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Anyone else find when you knock the clips out they chip the tiles ?
So you don't use a normal hammer then ?Try using a rubber hammer instead
Your winding us up!So you don't use a normal hammer then ?
his joking lads I hopeSo you don't use a normal hammer then ?
It happened to me two times in 5 years. always lining walls, tiles 100x30 porcelanosa rectified. probably, soft material, possibility chipping. Now, when I see similar tiles, 1mm clips use, add 2 mm spacer cross, I solved the problem. I always use a rubber hammer to remove.Anyone else find when you knock the clips out they chip the tiles ? Using 1m long tiles at the moment and went back to fixing them the normal way as got fed up of them chipping tiles in the last bathroom.
Reply to Lip clips and spacers in the Canada Tile Advice area at TilersForums.com
