Discuss lifting wood floors in the Canada Tile Advice area at TilersForums.com.
AliGage
Subscribed
screwed mate , non floater :)
Find a whole board that's accessible, take the screws out, break the tongues and lift.
Once you get the first one out and can see underneath youll get a better idea of how to remove it, joist positions, pipework etc. Wouldn't go straight in with a ripsaw, catch any CH pipes that those wonderful plumbers have left right at the top of the joist and your behind before youve begun.
Reply to lifting wood floors in the Canada Tile Advice area at TilersForums.com
  • Question
Bathroom floor. I would be grateful for advice on how to prepare my bathroom sub floor ready for tiling.I have removed the floor boards and plan to lay 18mm WBP plywood.The question is, what...
  • Question
  • Question
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
  • Question
