Discuss Leak from Shower in to Kitchen Ceiling in the Australia Tiling Forum area at TilersForums.com.
U
Umeet2000
Hi all
We have been having this problem since we moved in to our house 2 years ago.
We noticed water coming through our kitchen light in our kitchen one day. We got a plumber round and he identified some loose tiles in our shower cubicle. We replaced the loose tiles and the problem resolved itself.
12 months later we got our downstairs Kitchen and Living room renovated with an extension too. Whilst the work was ongoing there seemed to be another leak in to the Kitchen. Luckily as it was a construction site it did not cause too much damage. It looked like the issue came from movement in the wall as here were some loose tiles (different wall to the first problem). When we removed the tiles the wall was very wet. We dried the wall, put in some new backer board and got it retiled. And put an extra layer of corner tiles in to make it as sealed as possible. The problem seemed to be resolved again.
Now it is another 9 months and we have a watermark in our kitchen ceiling (newly remodelled!!!) I have looked at the tiling and there does not appear to be any cracks or loose tiles. There is one that is slightly moving when i push it.
I just don't know what to do - do i try and break some more tiles to trace when the water is sealing through? Do I rip out the current shower and tray and replace it so i have peace of mind? Do I try and go through insurance?
Umeet
Time's Ran Out
'There is one that is slightly moving when I push it' - sounds like you've identified the problem.
With the ongoing scenario you've mentioned I'd suggest a complete strip out.
Colour Republic
if you've already retiled (and assuming it was tiled and sealed correctly) then the problem might lie elsewhere, especially seeing as it seems to reappear after a number of months, such as the tray not being supported well enough and moving
Looks like a full rip out to get to the bottom of it seeing as the repairs haven't made much difference over the long run.
jollyroger
Rip out and get a pro in. Your shower needs to be properly tanked and tiled. Trying to "fix" it now and again will not make the situation any better.
cam_low
Points
1,048
South Woodford
I'll be working over Hemel Hempstead from November 6th onwards for a week or so. Could always call in and have a look but the advice given above is where you are at !
White Room
Let us know where you are and I'll pop in and say hello...then you can make me a cuppa:smilewinkgrin:
AMtek
the tiling is one of the last things i would be looking at to be fair. If the plaster/ plasterboard was replaced with backer board then was it dropped in behind the tray and sealed between the tray and board before tiling? were both walls in the shower area replaced with backerboard? have you tried dropping the trap off the tray and sealing it again? is the silicone between the tiles and tray intact? better to get in the shower and have a look as the tray can drop slightly with a person in it and open up a split in the silicone
AMtek
Try spraying the shower hose straight into the trap for a good while and see if you get water coming through the ceiling, if not then its the walls or the silicone work
Reply to Leak from Shower in to Kitchen Ceiling in the Australia Tiling Forum area at TilersForums.com
