Discuss Laying 600 x 600. Advice please. in the UK Tiling Forum area at TilersForums.com.
STINGRAY30
hey guy, nxt week i am laying 600 x 600 tiles in my living room,
the floor is 18m2 and is concrete,
just wondering how you guys would approach it??
thanks
Bolter
thanks
It depends on the shape of the room, number of doorways etc. Do you have any pictures of the room?
Its mostly best to centre the room both ways and walk or dry lay the tiles to the edges of the room to make sure they fit. You centre the room, so you have the same cut either side, both ways. This of course can be adjusted somewhat if you need to.
Once the centre has been found and eveything fits, ping a chalkline down the length of the room, making sure its straight and centred to your mark. Start laying tiles off this line, starting at your mark you made.
Plan where you are tiling, as you dont want to tile yourself into a corner :)
Bolter
THANKS BOLT, and what addi would you use and trowel size?
Probably 10mm notch or bigger. Addy is dependant on what type of concrete really. May need priming first, or levelling.
Have you checked the floor with a straight edge? The flat-er the floor, the easier the tiling.
Picture would help alot!
macten
1,158
Nottingham
I would use a PTB and PTB trowel
H
hillhead
In a living room i would centre on the main feature.ie a fireplace.its mostly in middle of wall but tiles look well centred on it.you could even do field tiles on the 45 and border with half tiles etc.looks well when well done.
STINGRAY30
thanks guys, i have a 10mm round notch rubi, would that do the job??
am getting keys to house tomorrow then ill check the floor??
the door is in the middle of the room, how do i work to that if its in the middle and not the corner??
Bolter
thanks guys,
#1 i have a 10mm round notch rubi, would that do the job??
#2 am getting keys to house tomorrow then ill check the floor??
#3 the door is in the middle of the room, how do i work to that if its in the middle and not the corner??
#1 If the floor is flat, 10mm is fine.
#2 Check the floor for humps and low spots. Put a very long level or straight edge over it in various places, and look under it for high and low spots. If its bad, I would try latexing the floor flat before you tile it. Trust me, its easier this way. If you need latexing advice, ask.
#3 Again start by marking the floor in the centre both width and length. Then dry lay a few to see what sort of cut you get into the door way, and the edges of the room. If its not quite right, adjust the centre line slightly, and check again. Personally, and it is only personal opinion, floors looks better with the same cut either end of the room.
If anything Ive said, your not sure on and want me to elaborate on, either post up, or PM me. :thumbsup:
STINGRAY30
cheers bolt, will get back to you when i get in.
i have a 2m spirit level, is that a long enough straight edge??
Reply to Laying 600 x 600. Advice please. in the UK Tiling Forum area at TilersForums.com
